Gray line on Bizhub C7000
  • ANIP87
    • Feb 2022
    • 9
    [Misc] Gray line on Bizhub C7000
    Hi all please help me.
    I have a problem on bizhub c7000. The problem is gray line.
    I already check drum unit, dev unit, charging, transfer bel unit, writing unit but the problem still there.
    Any solution please...
  • lartis.aineias
    • 78
    Re: Gray line on Bizhub C7000
    Try first to change the fiery cable!
    An 2nd i believe image control board
    Στάλθηκε από το AC2003 μου χρησιμοποιώντας Tapatalk
    • Toxic
      • 697
      If you output test prints from service mode is problem still there?
      • ANIP87
        • Feb 2022
        • 9
        Already change the fiery cable still problem. The gray line is there both from file and test pattern.
        • ANIP87
          • Feb 2022
          • 9
          Yes it is. i already take test pattern 58,53 & etc.
          If any black color will be any grey line sir.
            How did you 'check' those items?
            My guess is drum unit or cleaning assm.
              Replace K drum.
              • lartis.aineias
                • 78
                I see a digital problem.
                2 years ago I had about the same problem, after changing drum, laser, I changed the board and the problem was fixed.
                MCB1 board
                • ANIP87
                  • Feb 2022
                  • 9
                  Drum unit and Developing already change.
                  Cleaning belt had changed. +6281385267300 (whatsapp or telegram)
                  • ANIP87
                    • Feb 2022
                    • 9
                    MCB1 board
                    Many thanks. I have chnged mcb1 on july 2021, because of errors E006.
