C450i / MF 459 HV Problems.
  • OlivettiTechnik
    • Apr 2015
    • 8
    Good day,
    we have a bizhub C450i / MF 459 with the following problem.
    See photos.
    We have already renewed the following components:
    drum
    developer
    transfer belt
    transfer roller
    HV board
    Unfortunately without success.
    The only slight improvement was when you increased the Vpp-K1 and Vpp-K2 values
    Thank you for your help. (Sry for the google translation)
  • tsbservice
    Field tech
    • 8075
    Re: C450i / MF 459 HV Problems.
    Originally posted by OlivettiTechnik
    Good day,
    See photos.
    [ATTACH=CONFIG]52086[/ATTACH][ATTACH=CONFIG]52087[/ATTACH]
    drum
    developer
    transfer belt
    transfer roller
    HV board
    You've changed whole units(not only drum cylinder and/or developer powder) with new ones?
    What should be on second page?
    • techsxge
      • Jan 2022
      • 660
      Good day,
      See photos.
      drum
      developer
      transfer belt
      transfer roller
      HV board
      To me this looks like a issue with the fusing unit. Atleast the black dots on the MM List. What happens if you go to Service Mode -> Test Mode -> Halftone Pattern, set density to around 60 and then print Black (1PC) and Black (4PC) ?
      • OlivettiTechnik
        • Apr 2015
        • 8
        Yes, all the parts listed are new to the machine.
        Here the 2 pictures this time not scanned but in photo of it
        (Halftone Pattern, set density to around 60 and then print Black (1PC) and Black (4PC)
        • and
          • Oct 2011
          • 99
          I have a C300i with same problem on Y/M/C, when i print counter it's ok when i print color i have a lot of colored dots. I don't think it's a fusing issue. At the moment i regulated Vpp.
          • techsxge
            • Jan 2022
            • 660
            Did you forget to add the photos? I cant see them.
            • techsxge
              • Jan 2022
              • 660
              Dots in this quantity are only coming from a few parts in my experience: Drum unit, Developer Unit and Fusing Unit whit Fusing Unit being the most "popular" one for making this.
              If i look at the other Page, the distance between the different color shades are looking like the second cylinder/drum inside the Fusing Unit to me.
              Maybe OP could also try to see if he can spot any of the dots or lines on the drums of the Fusing Unit but this isnt happening very often.
              But to your Issue: If the non Coloured prints are ok, then its not a problem witht he fusing unit. Instead, i'd check the drum units and developer units and either clean them or even replace them.
              • OlivettiTechnik
                • Apr 2015
                • 8
                Sry here the pictures. Please ignore the yellow comes from the cell phone camera.
                • OlivettiTechnik
                  • Apr 2015
                  • 8
                  Sorry here are the pictures. Please ignore the yellow, it is from the smartphone camera.
                  • techsxge
                    • Jan 2022
                    • 660
                    Sry hier die Bilder. Bitte ignorieren das Gelb kommt von der Handykamera.
                    [ATTACH=CONFIG]52112[/ATTACH]
                    [ATTACH=CONFIG]52113[/ATTACH]
                    I'll stick with english here, if you want to speak in german send me a pm.
                    Ok now this does look like the developer unit. Have you actually replaced the whole unit or just the developer itself?. To make proper measuresments, at what density have you made those prints?
                    • OlivettiTechnik
                      • Apr 2015
                      • 8
                      We replaced the whole K Developer Unit. Nothings changed as I mentioned above.
                      Density print is normal. Improvement by increasing the Vpp-K1 and Vpp-K2 values.
                      INFO:
                      This week the Konica Minolta technical support will be around. Posting the results later this week.
                      • OlivettiTechnik
                        • Apr 2015
                        • 8
                        Yes we changed whole Units.
                        The second page is a service mode yellow halftone gradient print. The machine prints these black lines on everything.
                        • tsbservice
                          Field tech
                          • 8075
                          Check PH unit(laser).
                          • tsbservice
                            Field tech
                            • 8075
                            Any news on this problem?
                            • Gift
                              • Mar 2011
                              • 2459
                              This looks like some voltages went through the roof - I've seen this if you try messing around with used drums/devs (last case I had was with drums, kind of the exact image error).
                              Rotation time infos doesn't really indicate new units. If you put "newish" units into a machine with a high color volume and the machine doesn't reset them you end up into trouble
                              because the machine still tries to compensate a worn out OPC material leading to problems if the units are actually in a way better condition
                              I was able to recover this with fiddling with some voltages but can't recall the exact steps, sorry.
                              Guess you can also try and "chip" used drums - as long as they are really in good condition with low meter.
                              Start comparing the voltages with a working machine.
