Konica FB08 (000.00) error code
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Wondering if anyone has seen this error before. I have yet to go out but will go out and try a FW update for starters. Problem:
    Code FB-08 code. Konica Bizhub 4050
    From the manual : Abort code,
    ABORT CODE
    4.1 Troubleshooting of the abort code
    • The machine displays an abort code (F###) on the operation panel as it becomes unable to process tasks properly through its software
    control.
    • When the system program is aborted, check the electrical component, unit, option, and connection relating to the specific type of the abort
    FB-08 error:
  • tsbservice
    Field tech
    • 8053
    Re: Konica FB08 (000.00) error code
    I will get with me DF from parts machine if possible.
    • blazebusiness
      • 1257
      Not a bad idea, I'll bring one with me.
