Morning all! Have a weird one I have been fighting on one unit. C550i with an FS539 attached to it. End user randomly gets the "Please remove paper from output bin" when printing or copying to tray 2 on finisher. End user waves their hand above Tray 2 and the unit continues to work correctly. Seems like this happens randomly. I found a doc on on the service portal that instructed to turn en engine switch 16 to help with this issue and issue persisted. Newest function version firmware is installed on unit and finisher. Changed out the sensors that detect paper in tray 2, changed out the tray 2 "paw" sensor. Replaced finisher with different unit and issue persists. Just reaching out to see if anyone else has run into this issue.
Thank you!
JC
Thank you!
JC
