Scan To O365
  • Gaffers01
    • May 2011
    • 334
    Scan To O365
    This is driving me NUTS
    I have a C227 that I cannot get to scan using office 365 account, things I've tried
    Updated firmware
    SMTP authentication using a known account
    Connector
    Direct Send
    Ports 25 and 587 and also no SSL/TLS
    With a Certificate
    Without a Certificate
    I checked these setting using Telnet and all connected how they should.
    I have a C227 in our workshop which I setup using the connector settings and it worked first time. So I backed up that device settings and installed onto the problem machine but still same issue.
    After no success with the above accounts I tried using a Gmail account which does work (port25).
    The customer doesn't want to use the Gmail account, they want to use the O365 account so this is not an option at this point.
    If anyone could help it would be greatfully received
  • tsbservice
    Field tech
    • 8002
    Re: Scan To O365
    Sounds you covered almost everything. At this point I will try to initialize network settings data [System 1] -> [Initialization] at first and after that maybe even clear all data.
    What is the error code?
    • Gaffers01
      • May 2011
      • 334
      Re: Scan To O365
      Yep tried initializing the network settings aswell.
      Depending on what port 25 or 587 I got different errors which were either 535 and 435
      which I think both point to authentication issues which is obviously odd with the connector as there is no authentication.
      • Gift
        • Mar 2011
        • 2459
        Re: Scan To O365
        On other KM's you have to edit some Bit SW in order to allow a higher TLS standard - not shure if it's the same with the c227 though.
        I think there's more information about this in other threads regarding o365 + KM.
        I've also seen some O365 accounts with 2 factor authentification enabled - that's not cool for scan-to-mail^^
        I think you can check this if you test the account with O365 web log in.
        • emujo2
          • Mar 2017
          • 1579
          Re: Scan To O365
          Office 365 settings...
          Hostname: smtp.office365.com
           Use SSL/TLS: Start TLS
           Port Number: 587
           User ID: Must be a valid Office365 email address
           Password: Must be the password for the above email address
          Selfsigned SSL Cert 256/2048
          Correct time and date
          Assuming your network settings are correct and the machine supports TLS this should be all you need to get office 365 working. Also, what do you mean when you say "connector" are you using an app to scan to O365?
          • Max
            • Oct 2011
            • 555
            Re: Scan To O365
            There is tech bulletin. Pm me you e mail. I'll send to you.
            • rrrohan
              • Sep 2011
              • 1977
              Re: Scan To O365
              Disable all but TLS1.2
              Sent from my Pixel 4 XL using Tapatalk
              • Gaffers01
                • May 2011
                • 334
                Re: Scan To O365
                 Port Number: 587
                Hi emujo,
                The connector is used if the customer has a static Ip address so they can send without authentication.
                The connector is setup in the admin settings on the exchange part in Office 365.
                • Gaffers01
                  • May 2011
                  • 334
                  Re: Scan To O365
                  Ok ill try this, admittedly I had only tried with them all enabled.
