Konica Minolta press c8000e sc6704
  • Ahmed Bushara
    • Mar 2015
    • 26
    [Error Code] Konica Minolta press c8000e sc6704
    Dear all
    I have a problem consist of two parts firstly when I sent a print job the machine receiving the order , the LED start blinking when receiving job complete the machine does not print the job secondly the error code C6704 appear after many order send ,may I have your help to solve this problem thanks all.
    by the way I try many different driver I use fiery driver and many others drivers but the problem still
    Awaiting for your kind response
    Thanks and best regards
    Ahmed Bushara
    Electronic Engineering technician
    Mobile: +249-999198804 /+249-123198804
  • zayonc
    • Jan 2022
    • 49
    Re: Konica Minolta press c8000e sc6704
    Do you have a scanner on your device?
    • Ahmed Bushara
      • Mar 2015
      • 26
      Yes I have but I try to disable it but I can't, I use service manual to find out if I can use deep switch to disable the scanner but I can't find the special number to use through deep switch
      Thank you for your kind response
      Ahmed Bushara
      • zayonc
        • Jan 2022
        • 49
        C-6704 (Scanner: Scanner time out)
        1. Update the firmware to version I0-G00-60 or later.
        (F/W Ver.I0-G00-60 was released by DLBT1312543EN)
        It is necessary to apply the latest C-ROM at same time.
        2. Replace the parts in the following order.
        - Memory control board /1 (A1RFH020)
        - Memory control board /2 (A1RFH040)
