bizhub 5020i drum life end
  • jwai
    • May 2018
    • 502
    Hi,
    One customer has 5020i which printed 14K.
    Few days ago they called replace drum message displayed, I checked that life and 43% remaining, restarted machine and it worked fine.
    This day they called again this same issue, I tried to reset the life to 100% and it can be printed again.
    What the reason about that? Thanks a lot.
  • tsbservice
    Field tech
    • 7910
    Re: bizhub 5020i drum life end
    Maybe Firmware anomaly, try latest.
    • Gift
      • Mar 2011
      • 2444
      Originally posted by jwai
      Hi,
      perhaps something is wrong with the drum chip or the contacts
      • Gift
        • Mar 2011
        • 2444
        Hi,
        • tsbservice
          Field tech
          • 7910
          No drum chip on this model.
          • occus
            • 317
            Are you shure that's the right allert message? Do you have seen this with your own eyes?
            14k is near to the factory toner capacity (12k i guess) sometime customers can't read the exactly alert message.
            This brother device count from 0 to the end 50'000 after you got the alert otherwise it must be a firmware bug..
            I have a few in the field but until today i have not seen such behavior.
            • jwai
              • May 2018
              • 502
              Yes, I saw myself. First visit the machine displayed replace drum alert, I restarted and OK。
              Second visit when I got a test print it displayed again after data had been received。
              This day I had a visit and cleaned contacts of drum unit and machine side, let's a test。
              • Gift
                • Mar 2011
                • 2444
                True, this is the brother engine
                I know brother can display a "clean drum" message if they detect a HV leakage from the charge corona - using the charge wire cleaner won't hurt
                • tsbservice
                  Field tech
                  • 7910
                  I have hundreds of these Brothers in field and never seen this message prematurely.
                  @occus, I believe they count drive counts so drum end life(change drum) message will pop up depending on usage - pre or post 50k prints.
                  • tsbservice
                    Field tech
                    • 7910
                    Hi,
                    Aah, now I see it. It has nothing to do with drum life message it's to clear drum charge wire. Teach them how to do it and describe that it's normal and should do it when changing toner or when machine asking.
