C3350i J-1101 J-1102
Re: C3350i J-1101 J-1102
Wise choice. Even if it would work the running cost is still high. Did forgot to mention the touchscreen can go goofy too.WhateverComment
So two things that works against it. The plastic shaft on the separation roller wearing down the thinnest of layers and causing friction, grease is working until i can get it replaced. Then the restive registration sensor that is explained by the bulletin to be out of position causing the paper to stop for registration before its past the middle of the roller. Fixed that by sticking another 2mm of padding on top of the perfectly good existing padding.
Arrg its one of those fixes i just can't trust. Well its working for now.
Now just the DF issues where the paper does not get ejected completely.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
The only exception is bizhub 5020i series based on proven Brother model quite bulletproof, easy for customers and service.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
As usual KM screwed A4 models. This time they went with their own design instead of borrowing from other manufacturers (also very problematic). You can squeeze 4e A3 series up to several times of parts life before they react dumping developer but at this point you are way ahead, here with C3350/4050i and so on imaging units and toners can fly out diabolically fast not to mention problems like this jamming on fairly new machines with low counter.
The only exception is bizhub 5020i series based on proven Brother model quite bulletproof, easy for customers and service.WhateverComment
