Konica ineo 227 - stained outprints
  • Shakur
    • May 2021
    • 13
    Hello everyone,
    I have a KM 227 mono, after 110k outprints it started to make problems with outprints quality.
    Changed develop and drum, it helped for 2 weeks, then same problem.
    Anyone got ideas? SKMBT_C28022051310120.pdfSKMBT_C28022051310121.pdf
  • Toxic
    • 696
    Re: Konica ineo 227 - stained outprints
    You replaced OEM developing unit and drum, whole complete units?
    What kind of toner used, OEM or some replacement?
    • Shakur
      • May 2021
      • 13
      Develop OEM, Drum regenerated, toner not OEM, some replacement.
      • Gift
        • Mar 2011
        • 2449
        That's dev loss - either the compatible parts are crap or the air ducts and toner filter is stuffed with dev/toner. A lack of ventilation can cause this. Somethimes HV issues can also lead to dev loss. It's not necessary the HV board - sometimes it's charge leakage from a bad drum/corona/charge roller/contacts.
        Doesn't this unit have a complete image unit with drum+dev? How come the dev is original but the drum is regenerated?
        • Shakur
          • May 2021
          • 13
          Drum+dev is not stick togheter. I ordered OEM dev and regenerated drum by myself, thaths how it comes. Thanks for reply, so ill try to clean it up, otherwise maybe replace HV is the way...
          • Toxic
            • 696
            I suspect toner is making problem and maybe drum too and developer is propably contaminated.
            Have few 227 with 600-700k and never had any problem but i use OEM toner and OEM drums.
            I only replacing developing units on machines where user puts some other toner than OEM.
            In this combination drum can last easy about 200k prints without any output quality problem.
            Ps:when you rebuild drum did you use chip to reset drum life or not?
            • Shakur
              • May 2021
              • 13
              Yes, i did, chip is new
              I tried other drum (not OEM), other toner (not OEM) and nothing changed, still same problems, so firstly i aim at HV, dunno.
              • abbasly.tech
                • 8
                Most likely your developing unit is dead due to not using OEM toner. We have encounter similar issue from user using aftermarket toner causing dotted & lighter output.
                At the end, We billed the user a new developer unit, OEM toner and service charge to clean the hopper unit as well.
                • Shakur
                  • May 2021
                  • 13
                  Thanks for your reply. You are right, the problem was low quality toner, that was damaged develop. Thanks for your advices, have a nice days
                  • allan
                    RTFM!!
                    • 5459
                    Had plenty of trouble with compatible toner. In all the cases I had the machine always over toned. Have not seen it causing depleted developer.
                    Whatever
