C-368, not able to update F/W
  • techsxge
    • Jan 2022
    • 660
    #16
    Re: C-368, not able to update F/W
    Originally posted by Oystercopy
    Thanks for all the replies guys. I looked at Enhanced Sec. Mode, everything normal. Checked S/Ns and all seems well. I will have to see if I can re-try the FTP upload and see what happens.
    OC
    Have you done a trouble reset yet? For testing purpose, i'd also reset the CE Password.
    idk what it is called at KM, but with Olivetti (Rebranded KM, same machines from the inside) we have something called i-options. If you have something like that in KM installed, check for the Antivirus kit. I'd guess that the antivirus blocks the USB from working.
    Also, check if the USB (Port) is useable for USB Print.
    If all that doesnt work and you decide to stick with the Internet ISW and need help setting everything up, drop me an email
    • techsxge
      • Jan 2022
      • 660
      #17
      Originally posted by allan
      Another silly question. Did you use different thumb drives or tried to format it?
      Had one case where i went thru 3 different memory sticks before i had luck. Strange thing if the same drives that failed to load firmware worked fine on other models.
      If the drive has been partitioned or made to boot it does not work. Think i have used the app called Rufus to fix the formatting before.
      I can confirm. I used to use Windows format function for drives but realised its kinda destroying the sticks for some reason bc most sticks i used with a windows computer stopped working after around 100 reformats.
      Then fully switched to linux and never had an issue, coworkers who kept on using windows then started using rufus too and there are no more "failing" sticks around.
      Just format it to UEFI:NTFS when using Rufus. Or use gparted like i do
