Language bizhub C308
  • -ph-
    • Jun 2009
    • 30
    [Misc] Language bizhub C308
    Hello,
    I have a C308 and I want to change the language but I only see English in the settings:
    I performed clear all data
    upgraded the fw to version GCA-X4 msg97 and even tried an older fw (same problem)
    HDD is set to installed
    Never had this before for as far as I can remember, anyone any idea/advice?
    Grtz
  • tsbservice
    Field tech
    • 7986
    Re: Language bizhub C308
    When firmware update screen appears in the right screen side can you see Language selection tab?
    Touch [Language Select].
    On the Language Select screen, select a language to be displayed on the LCD area of the control panel, then touch [Fix].
    NOTE
    ▪ The language selected on this screen is displayed on the "Language Selection" screen of Utility.
    ▪ Up to 9 languages are selectable. However, Japanese and English are essential options.
    • -ph-
      • Jun 2009
      • 30
      Thanks for your reply, much apperciated!
      Yes I can see the language selection in the fw update screen, I tried the update with all languages selected and with just a few languages selected.
      If I have to make a guess I would say this is something that can be controlled by a soft sw setting?
      grtz
