Bizhub 758 Light prints
  • slytukana
    • Feb 2015
    • 48
    I am experiencing a light print on bizhub change drum and developer still the same.
    When printing on double sided one side is printing well while the other side is light. Single sided all prints are light try changing paper but still same.
    Appreciate your help
    Sent from my SM-A217F using Tapatalk
  • allan
    RTFM!!
    • 5462
    Re: Bizhub 758 Light prints
    Could be a transfer problem. Secondary or primary. Would lean toward secondary with one side being better than the other.
    Stop the print mid cycle and check the density of the image on the transfer belt.
    If the image is light on the transfer belt then pull the drum mid print and check the density on the drum.
    But the IDS value could also indicate where the issue lies.
    Play with the transfer voltage values in service mode to see if tat helps.
    Any P-codes?
    Could be bad contacts to the transfer roller, ITBU or a bad HV board.
    Whatever
    • slytukana
      • Feb 2015
      • 48
      Thanks will do that and check when printing double sided the one side is ok but other side is not still light print also doing multiple one side print is light
