C450 intermittent color registration
  • sunsetoutpost
    • Nov 2009
    • 54
    This C450 has intermittent color registration, not on every copy but gets worse the more copies run (28# paper). New IU's, belt changed. Looking for any other opinions before I pull the board box and change out the motor.
  • mearmi
    • Oct 2010
    • 350
    Re: C450 intermittent color registration
    Are you getting any Error Codes? Run Gradation Test patterns. Also Check belt drive assembly.
    • rrrohan
      • Sep 2011
      • 1977
      C450 + C351 Color Shift.pdf
      • allan
        RTFM!!
        • 5462
        Check if it register any P-codes. Respects for still having one running. Switch it on make some coffee read your emails may be it ready... send a print job scratch your balls for a while and wait in front of the machine for the print to come out.
        Is the transfer roller rotating freely. How many clicks on the machine?
        Whatever
