C360i Colour mismatch
  • Kenny
    • Jun 2009
    • 529
    Hi guys,
    got a konica minolta C360i that isnt printing colours correctly,
    Essential Healthcare CuroCell A4 Quick Reference Guide_AW.pdf
    The purple border is coming out more pinkish and the grey borders around the images are coming out blueish rather than grey,
    customer is printing from MAC OS BIG SUR.
    tried adjusting various settings with colour and also calibrated machine but still cant get it right
    S45C-6e22071501350.pdf - how its coming out
  • techsxge
    • Jan 2022
    • 660
    Re: C360i Colour mismatch
    What settings and what calibration did you try?
    • Kenny
      • Jun 2009
      • 529
      tried changing the following:
      600dpi - 1200dpi
      document types from photo and document
      pattern - coarse and fine
      Image Compression - high compression/best quality
      not the best with MAC's either
      • techsxge
        • Jan 2022
        • 660
        600dpi - 1200dpi
        Color is normal when printing Test Page from Machine? If yes, maybe update your driver or change it for another one.
        Or you try to do Gradiation Adjustment in Service Mode
        • Kenny
          • Jun 2009
          • 529
          the test page and halftones are spot on, as i say ive done the calibration on the machine is perfect, just sending this document it doesnt come out right
          • techsxge
            • Jan 2022
            • 660
            Well this purely sounds like a driver issue then. Is the Driver confirmed to work with the OS version? Might be possible to use a generic driver too but i usually just try to convience the customer to throw apple out, it gives nothing but trouble in network use.
            I'd try a different driver with up to date firmware combinations. If i cant get this to work i'd usually offer to install a print server running unix systems (Like a RaspberryPI) that handles all print jobs. Usually have one setup anyways
            • Kenny
              • Jun 2009
              • 529
              never mind the machine needs a fiery, tested the document on one of our fierys in the office and came out perfect!
              thank you for your input
              • techsxge
                • Jan 2022
                • 660
                Well that was easy to fix then.
                Your welcome.
                • romario
                  • Jun 2020
                  • 192
                  Hi guys,
                  [ATTACH]53996[/ATTACH]
                  [ATTACH]53997[/ATTACH] - how its coming out
                  I have this constant problem with clients who buy an office machine for graphic arts, I had to take graphic arts and graphic design courses, apart from the fact that a machine with fiery processing of the file is better and the colors are handled differently, your machine without fiery is fine, what is failing is the client's file has many layers, for that reason on page number 1, on the right side the image comes out with a white background, sending that file again converting it into AI using the options in graphics better quality should come out very well, another recommendation transforming the file into JPG should come out well...
                  thanks
                  • Hansoon
                    • Sep 2007
                    • 3389
                    But not a cheap one....
                    Hans
                    • REGSIS
                      • May 2016
                      • 435
                      There is an option in acrobat for using native machine colors.
                      Also try to print with different pdf program.
                      I remember that I tried 3 different programs in linux, and only Acrobat gave identical colors.
                      If airprint driver gave bad results try KM PS driver instedad.
                      You should get "normal" printout withou Fiery!
                      • techsxge
                        • Jan 2022
                        • 660
                        Hans
                        i still reckon to check drivers. also what romario said might apply, but sometimes clients can't do certain things for various reasons and then it is not an option.
                        If tech and client are fine with just replacing fiery, why not? You could still troubleshoot it further in your own four walls. That is what i do too depending on the customer
                        • Gift
                          • Mar 2011
                          • 2459
                          I don't see much of a difference between the scan and original file on my monitor.
                          It looks like it has been printed on standard office paper and not on smoother color copy paper.
                          Some of the other image errors are probably due to a faulty file or using macOS "preview" tool instead of adobe acrobat reader.
                          Preview Tool = shit
                          Acrobat Reader = best choice for printing PDF files
