1051 with C-3905 accessing service mode
  • cmitch
    • 53
    I cleaned T2 and now want to reset DIPsw 3-1 from 1-0. I've done this over a year ago but I cannot remember how to get in service mode with C-3905. I remember it involved access key but don't remember procedure. Stop 00 Stop 01 alone does nothing. Any help?
  • techsxge
    • Jan 2022
    • 660
    Re: 1051 with C-3905 accessing service mode
    Quite sure you need to be on the utility screen to do the stop 00 stop 01 procedure if you meant that. Or it was Menu -> Stop 00 Stop 01
    • cmitch
      • 53
      Been working on it a little over a year now. I am in utility screen. Stop 0-0 Stop 0-1 does nothing on the C-3905. It is a safety lock out and takes another procedure to get in service mode but I don't remember exactly what it was. I had it wrote down but paper is gone. I know it involved access key but I've tried every combination I can think of and nothing.
      • romario
        • Jun 2020
        • 192
        turn off the machine, leave the utility counter key pressed, turn on the machine with the key pressed and you should enter
        thanks
        • cmitch
          • 53
          Thank you romario. This did the trick. Reset DIP and all is well. Been printing for awhile now.
