BH-C-284e, "An Internal Error Has Occurred"
  • Hansoon
    • Sep 2007
    • 3391
    From time to time BH-C-284e is showing at start up "An Internal Error Has Occurred.........blablabla"
    Machine reboots from itself, then everything seems OK.
    Should I worry?
    Hans
  • techsxge
    • Jan 2022
    • 660
    Re: BH-C-284e, "An Internal Error Has Occurred"
    Maybe replace HDD. Seems like it slowly dies.
    Could also be a part like fusing unit with bad connection. Had this Error Message on two occasions
    • Gift
      • Mar 2011
      • 2459
      Does it show up for no reason or only if somebody initiates a print job? Any errors logged in service mode?
      HDD is possible or "crap data" from the network (can happen if someone uses generic drivers, wsd port...).
      • allan
        RTFM!!
        • 5462
        Check the error code logged. How often? You can set it not to restart automatically to catch it in the act.
        Whatever
        • tsbservice
          Field tech
          • 8031
          Looks like bad TCR values check it in state confirmation. Probably white bushings on affected colour need replacement. Easy job 👍 You can always consult with MML list for past codes, errors etc. Remember MML and halftones are tech's best weapons within service mode
          • JasonSBE
            • Apr 2014
            • 187
            This could be a great many things. You're going to need to get into service mode and check the code history before it can be properly diagnosed.
