C454 black drum black band
  • positiveg
    • Jun 2018
    • 299
    There's a black band I found I think on two separate black drums. I just realises that the black band shows uo I think was on a previous drum as well not sure.
    I think it may have been causing some light prints on the far edge of the paper 11x17 and 12x18 prints.
    I put in an old black drum, waiting for rhe new one which is set to deliver tomorrow.
    I'm attaching a photo of the drum
    Sent from my SM-G780G using Tapatalk
  • allan
    RTFM!!
    • 5462
    Re: C454 black drum black band
    Check if the develop on the roller is not raised that side. Could be that is still has an old type mag roller without the splines that got polished.
    Whatever
    • Toxic
      • 697
      Or dirty charging corona mesh
      • tsbservice
        Field tech
        • 8016
        Looks like rebuild drum unit?
        • positiveg
          • Jun 2018
          • 299
          Yeah will pull the developer if it continues having that issue. The two prints I ran after they came out clear. Not aure if it will reappear after a while. If it does then I will definitely pull the developer and take a look. Thanks much
          • positiveg
            • Jun 2018
            • 299
            This one might be
