bizhub C558 more issues after transfer belt change
  • techsxge
    • Jan 2022
    • 660
    Hi guys i need some help asap.
    i had an C558 where there was a red line on color prints. No bid deal just switched out the mgenta drum unit because it reached life twice.
    While i was at it, i did a all around check on the machine and saw that the transfer belt was damaged but nothing critical. Had a brand new one in the workshop so i grabed it and placed it in the machine. I made sure to test it in the workshop ofcourse.
    Everything worked well at the customer. When i came back to my workshop, the assistant told me that the customer called us because since i left there are now loud sqeaiking noises (like from a mouse), streaks on the paper and yellow toner (I guess in a straight line again but customer did not specified that.).
    I am going to switch back to the old transfer belt tomorrow but i am not happy with keeping that one running and neither is the customer realy. I am also confused what could create the Noise exactly as in my workshop machines it worked perfectly fine
  • tech51
    • 846
    • tsbservice
      Field tech
      • 7986
      Re: bizhub C558 more issues after transfer belt change
      +1 to this. Also check that something isn't blocking waste section from discharging.
      • tulintron
        • Jul 2014
        • 668
        +1
        • techsxge
          • Jan 2022
          • 660
          thanks for the replies, i'll be on site in an hour or two and post my results... I have some bad feelings about this
          • techsxge
            • Jan 2022
            • 660
            Ok so i was able to solve everything yesterday...
            I was on site and checked the transfer belt. No problems found there. I checked the yellow drum unit and it was just worn out by time so i switched it and the yellow streaks went away. Then i got a light blue shadow in the background. turned out it was the cyan developer... I then refilled the developer and print looked good.
            Just before i was qabout to leave i needed to print out the counters for my paperwork and i noticed black dots on the bottom of the page.
            Checked the black drum unit and replaxced that one too. Then i printed another 250 pages of all colors just to be sure that i do not need to return the very next day. Found no more Problems.
            Kind of thinking that a paper clip or something went through the machine? I'll go through the replaced drum units, the transfer belt and the waste toner box if i can find something today. Would realy like to send the customer a bill given how they often manage to mess up stuff.
            • Sysco
              • Mar 2010
              • 43
              " the mgenta drum unit because it reached life twice. "
              How many count was in the mg drum unit?
              I never see much more in the 313 drum unit then 120k never in the china and the malay version too.
              Maybee the new france is going to higher but I not tested too much this new version drum unit.
              • techsxge
                • Jan 2022
                • 660
                The Magenta Drum Unit reached 194k, yellow and cyan similiar numbers
                Usually the drum units i have last between 90k-140k depending on how frequently the customer prints. Starting "cold" with 10 pages will cause more wear than having a "hot" machine where the customer prints every 30 seconds to 1 minute larger amounts of papers.
                • Sysco
                  • Mar 2010
                  • 43
                  194K whooo nice number.
