Minolta c364e error import to Adminitrator
  • victor the snake
    • Oct 2011
    • 10
    Hello good afternoon!
    I need a tip, when I use the "KONICA MINOLTA Data Administrator V4" program in models like the Minolta C454e and etc... The "Administrator V4" program to import equipment information, when I do the same in the Minolta C364e model, the program no matter the equipment information.
    Can anyone give me a tip on how to solve this problem, I would like to use the program because of the "Job Control".
    Thanks!
  • emujo2
    • Mar 2017
    • 1579
    Re: Minolta c364e error import to Adminitrator
    Here's a few reasons why PSDA fails..
    1. Not up to date, patches for later firmware not added (probably not a factor here, but we saw this during the transition from the e series to the 8 series.
    2. SSL, if enabled has a certificate that is too low (like when you can't access it via a web browser)
    3. Device settings outside the correct network scheme or defaults (snmp string wrong, Open API password changed)
    4. We had a few where a bad or de installed HDD kept it from reporting
    You should be able to see the log determine where the import process failed and trouble shoot from here..In some cases a factory default is necessary to get it back and responding. E
