print with ic-408
  • gamalmehdar
    • Mar 2008
    • 55
    print with ic-408
    when i print pdf document in c-6501 with ic-408 it show me load the paper 8.5 x 11 in any tray . but i need it in A4 papers . how can i resolve this problem.
    thanks for all
  • tervel12
    • Dec 2008
    • 65
    There is a setting in the Fiery to convert paper sizes A4/A3 to Letter/Tabloid. Turn this feature off in the setup menu.
    • HORSE
      • Mar 2008
      • 185
      Actually if you want to print on A4 (Metric) you would use convert Letter/Tabloid > A4/A3 not A4/A3 > Letter/Tabloid.
      Make sure that paper sizes are set to metric.
      These settings can be found in Fiery setup > PDL > PS
      Laughing......
      • Specilist KVN
        • Sep 2008
        • 79
        Even better is to simply turn OFF the paper conversion.
        this will pick the stock from your driver settings and will NOT try to convert.
