problem error d050 or e301 konica c258 and c308
  • enricocopyline
    • Jun 2018
    • 122
    Good evening everyone.
    I have a problem that I found in two konica minolta c308 and in a c258, sometimes it happens to me that the copiers restart themselves and give error code D050 and E301. updating the firmware does not solve the problem. it is a hard disk problem but I solve it by installing (with some difficulty because sometimes the installation does not start and I don't know why) the sata drivers more precisely the fw A7PU0Y0-0100-G00-84 (00).
    after a few months the problem comes back to me.
    I don't know if it's a problem with the hard disk but it shouldn't restart if it is corrupt.
    formatting does not solve the problem.
    Has it happened to someone or has any idea how to definitively solve the problem?
    thank you
    • 14643
    Re: problem error d050 or e301 konica c258 and c308
    thank you
    • strider5555
      • Jun 2008
      • 96
      Update firmware to GC1-X4 or newer, then set software SW 159 to Hex 08. This prevents the HDD and fax(if installed) from going to sleep when the machine goes into low power/sleep
      • enricocopyline
        • Jun 2018
        • 122
        OK thank you very much
        A7PU0Y0-F000-GCA-X4 is this firmware okay?
        is it possible to have a list of firmware by date?
        • strider5555
          • Jun 2008
          • 96
          There are too many to list. The latest maintenance release on KM US/Canada is GCG-X4. (released 9/06/2022) My recommendation is to flash base version G00-X4 and then do GCG-X4, set Sw 25 to hex B0. (Function Version 4.2)
          • enricocopyline
            • Jun 2018
            • 122
            it is more recent GCA-X4 or GC1-X4?
            • strider5555
              • Jun 2008
              • 96
              Yes GC1-X4 is from December 2019 and GCA-X4 is from November 2021
              • enricocopyline
                • Jun 2018
                • 122
                ok thank you very kind
                • enricocopyline
                  • Jun 2018
                  • 122
                  the sata-fw firmware I have this A7PU0Y0-F000-GXX-A6(00),
                  are there any new ones updated?
                  • strider5555
                    • Jun 2008
                    • 96
                    That is the sata recovery firmware, there is also Gxx-B0. which is the preventative firmware. Use the GXX-B0 firmware if no errors have occurred, and GXX-A8 to recover from the error. This updates the SATA controller firmware.
                    • enricocopyline
                      • Jun 2018
                      • 122
                      OK thank you
                      could you send me these firmware?
                      konica.copyline@gmail.com
                      thanks
                      • strider5555
                        • Jun 2008
                        • 96
                        I am not able to supply you with firmware unfortunately.
                        • enricocopyline
                          • Jun 2018
                          • 122
                          Does anyone have these firmwares?
                          • copyTcat
                            Senior Technician
                            • Apr 2015
                            • 58
                            Also looking for this firmware to solve E301. Anyone can post the latest firmware for c258 and c308 please
