Konica 7020 "Service Call F-26-3"
  • fishleg
    • Mar 2009
    • 426
    #16
    What does Sw3-7 do as its not listed in the service manual ?
    I too have had this one many a time if the dev has been correctly installed before as new then its usually just a case of the dev way past its sell by date.
    If you run L-detect the code you get usually gives you a decent hint.
    004 - Usually a bad td sensor
    005 - Bad Dev (you will never change this code tried everything and its always new dev)
    006 - Dirty sensor on drum
    New dev on L-detect is usually between 55-70 so that always will give you an idea on how decent the dev is.
    I've seen it once on the 7222 with the wrong toner which involves a major strip down of drum, recycle, dev just to remove all the wrong toner from the machine very costly.
    Does anyone know what the actual number on L-detect means I always just figured it was arbitrary number to give a guide but not really sure to be honest.
    • smiley
      • Aug 2008
      • 615
      #17
      3-7n in sofware swicht it will desable toner sensor and let you use the machine even it is over tone or have a error code f26-2 or 26-3.
      there is no glory without sacrifice
      • fishleg
        • Mar 2009
        • 426
        #18
        wow thats a handy one didnt know you could do that. So if you had this at a customers would it let the machine run till you get some new dev or will it just use the toner thats in the dev unit and just never add more ?
        • smiley
          • Aug 2008
          • 615
          #19
          yes it will just used the toner only on the dev.it will never drop toner from the cartrigde.
