very small text in Print Preferences window
  • rrrohan
    • Sep 2011
    • 1977
    I have a issue with really tiny text in print preferences window
    i seem to recall the M$ Surface Pro had this issue at one point but i dont recall what the fix was
  • trscolin
    • Aug 2012
    • 21
    Re: very small text in Print Preferences window
    Are you using the latest driver? There was some issues with print preference menu not displaying correctly.
    • rrrohan
      • Sep 2011
      • 1977
      i tried both
      PCL62021-12-22 11.2.0.0
      and
      PCL6
      2018-07-26 11.1.2.0
      Same issue.
      Not sure if its a high res issue. the screen is 4500x3000 res
      • and
        • Oct 2011
        • 96
        If you SO support use V4 drivers.
        i tried both
        and
        PCL6
        2018-07-26 11.1.2.0
        Same issue.
