Hello there!
I have a konica 7033, 230 volts. I'm planning to buy another one but the available copier konica 7033 with 110 volts only.
I would like to know the differences in parts of Konica 7033, 110 volts and Konica 7033,230 volts?
Are their boards, laser assy, etc. the same.
Of course they are different on their power supply unit. does the output (24vdc, 5vdc, etc.) of the copier power unit the same whether its input 110 or 230volts
For all i know on other copier machines, their fusing heater rods are different in voltage, and exposure lamps. while other boards and parts are the same.
Is this the same case with konica 7033?
