C3100P check I-Unit
  • endr_93
    • Oct 2022
    • 3
    C3100P check I-Unit
  • jwai
    • May 2018
    • 517
    Re: C3100P check I-Unit
    tried PWB-PRCB?
    • endr_93
      • Oct 2022
      • 3
      Originally posted by jwai
      tried PWB-PRCB?
      • Tech09
        • Apr 2020
        • 148
        Remove the High Voltage power supply and lightly rub the spring contacts with a scotchbrite pad, you will see they are kind of yellow from the factory, get rid of that yellow coloring. You can also rub the tops of the springs themselves. I also lightly bend the spring contacts towards the springs.
