Are TN015, TN010 toners usable on Bizhub 920, 1050?
  • ondemandprint
    • Sep 2016
    • 87
    Are newer toners such as TN010, 015, 017 compatible with old Bizhub 950, 1050?
    Of course after repacking toner into 950/1050 bottle.
  • emujo2
    • Mar 2017
    • 1579
    Re: Are TN015, TN010 toners usable on Bizhub 920, 1050?
    TN 014, 1015, 016 and 017 are interchangeable (bottles do not fit/work), Do not use any other TN in any of these models. You will have PCQ in just a few copies. E
    • Toxic
      • 698
      I tried several combinations but only TN-010 works ok in bizhub 950 because compound is identical.
      Ofcourse you must pour powder from TN-010 bottle to TN911.
      • Rolandito
        • Aug 2007
        • 91
        I am using TN710 to refill Konica TN911. OEM of course.
        I tried TN010 to refill TN911, but its not identical components, unless you use DV010 on konica 950.
        • Toxic
          • 698
          TN710 is also the same thing inside but not avaliable for me.
          I dont know how do you get info TN010 and TN911 is not the same?
          Spot the difference in the picture
          • emujo2
            • Mar 2017
            • 1579
            TN010, TN911, and TN711 are the same, 1052, 950, and 600/750. E
            • Rolandito
              • Aug 2007
              • 91
              Well. I tested in the field, in long term tn010 spills toner on transfer/separation unit in a Konica 950 and the machine gets dirty around drum . that is the reason that I say that TN010 an TN911 is not the same. It works fine but not optimal.
              I used DV010 and TN010 in Konica 950 with excellent resuts.
