replacing imaging unit on c350
+ More Options
Posts
  • rhager174
    How hard is it to replace the black imaging unit on konica minolta c350?
  • DallasTech
    • Feb 2007
    • 119
    I think this is actually a user replaceable part, I would say not hard at all.
    • JSC
      Gimp
      • Dec 2006
      • 618
      Easy..............Just make sure you or the customer gives the unit a good shake before its fitted.
      The gene pool could use a little chlorine.
      • 10871087
        • Jan 2005
        • 1143
        a well trained end-user can replace that item with ease.
        • gustavo.tsuru
          you can setup end off life in the service mode, when the unit show end off life, if this mode active, the machine doesnt work, be careful
          • pat
            • Mar 2007
            • 16
            The end of life is standard on "stop", I usually switch it to "not stop".
            The replacement of the IU can be done by the customer for sure, but it's certainly not a bad idea to give a demonstration when the first IU needs to be replaced.
            • nightshade
              Chromographic Supremesist
              • 158
              A trained monkey can easily replace it. But office employee who doesn't care about the machine can easily screw it up!!!
