454 itb
  • ARMAN.MZ
    • Sep 2016
    • 100
    454 itb
    Hi can i use 452 itb in 454??
    Telegram ID : @armanmahzun
  • subaro
    • Oct 2010
    • 1274
    Re: 454 itb
    No, the Toyota 3.4 does not work with the 3.7. How's that .
    Ask your question in the proper context. Without a brand or model name, you are just putting out numbers, though other might guess correctly, it is not the way to post your question.
    Smarten up.
    • tsbservice
      Field tech
      • 7924
      Re: 454 itb
      Directly I would say No. One is color and other black and white. If you are talking about BOTH color machines answer would be still No but you may have luck just swapping only belts.
      • subaro
        • Oct 2010
        • 1274
        Re: 454 itb
        According to google, the bizhub c452 itb is compatible with the following models.
        Bizhub C451
        Bizhub C550
        Bizhub C650
        Bizhub C452
        Bizhub C552
        Bizhub C652
        Bizhub C654
        Bizhub C654e
        Bizhub C754
        Bizhub C754e
