DI 850 problem
  • wwandrei
    • 40
    DI 850 problem
    Hello. Maybe someone can help me with this problem. So the facts are: I have a di 850 copier and i would be interested in copier firmware not for controller and the update software tool ISWTrans don`t now what version exactly. Can someone provide me this software. What happened exactly is that i have a Di 850 copier without motherboard and a konica dp85 printer desasambled. So i took the motherboard from dp85 and conected it to di850 but of course it didn`t worked ... it`s another firmware. I took the memory from the motherboard of another good DI 850 copier and plugged it on the motherboard in test and it worked in begining but then it stoped. After restart it stoped working as a copier. I put back the ram to the good Di 850 but it does`t works anymore. It enters in the state of ready to print but not ready to copy. I would like to make a firmware update on the copier. That`s why i need it. Thank you
    sry for my bad english.
  • wwandrei
    • 40
    what i need in fact is: for DI-850 firmware EURO for boards c1-c4; O1-O5; IMAGE; ADF; VIF. Can somenone help? Thank you!
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      All of this can be downloaded from the KonicaMinolta tech site with the proper credentials. You might find technicians hesitant to give away the info, tools and means to put food on their table by giving you this info.
      • wwandrei
        • 40
        I managed to get all the firmware versions for di 850 as follows :
        Program: ISWTrans 3.42E
        ROM VERSIONS:
        IMAGE : ver. 41
        CONTROL: ver. 20 (c1:18-0000; c2:11-0000; c3:14-0000; c4:11-0000)
        OPERATIONAL: ver. 41 (o1-05 : 41-0000)
        ADF : ver. 11
        VIF : ver. 11
        I have 2 Di 850 with problems. 1st one doesn`t have IMAGE firm installed so the only way I can install it is by entering HELP + FUNCTION mode.
        I have tried to write the firmware as written in the Service Manual :
        1st IMAGE ... but it stays in executing 4 about 40 min and then it says abnormal end. I can`n find out what is the problem?
        The other copier has all firmware installed but ADF that is not active and it detects my copier as a printer ... enters in mode ready to print ... and I don`t have a print controller. Can`t update ADF firmware it gives error 41 or 43(not much about those erros in SM), i`ve searched in sw switches to see if there is a way to enable or disable ADF but coundn`t find anything. Or is there a way to deleate all fw versions from the copier so I can do a clean install?
        What I do wrong? I`m kind of desperate `cause 2 good copiers now don`t work ...
        • tony_218
          • Oct 2007
          • 24
          di850
          amigos tengo el iswrm y algunos firwaros pero no los puedo instalar algunos son para actualizar en el sisitema de imprecion y otros para el idioma pero no los puedo instalar si alguien lo ac onseguido porfavor indiquelo
          • bamse
            • Mar 2008
            • 11
            hi i need, if you have for 7085?
            the same
            IMAGE : ver. 41
            ADF : ver. 11
            VIF : ver. 11
            • wwandrei
              • 40
              the same
              IMAGE : ver. 41
              ADF : ver. 11
              VIF : ver. 11
              Sorry but I don`t have for 7085 ...
