Toner block for users
  • Tiagocang
    • Feb 2022
    • 62
    Hello, if any1 could help me... when toner warning pop up if the user Open/close the door the mfp Will keep printing... I wanna know if is it possible to block the machine when the warning of Change toner appear
    Machine models c224/258
    Best regards
  • Gift
    • Mar 2011
    • 2459
    Re: Toner block for users
    Best regards
    Not that I know of - are you asking because of multiple orders from fleet management?
    • emujo2
      • Mar 2017
      • 1579
      All of these models have a option in service mode to turn off low toner message, and in the 8 series you can tell the screen to display # of days remaining, or % left. The issue with turning off the low toner message is...
      1. The typical user will not know they are low until the day they see the toner is empty message
      2. Now you have a down customer without toner wanting to know why the machine couldn't notify them 1 week ago that toner was low..
      3. They open the door, shake the bottle and close the door and a firmware bug resets the toner % back to 100%
      have fun.
      • occus
        • 339
        Best regards
        No, it's not possible. The tonerbottle has no chip, new toner or toner empty detection is made with a other solution. That's why the toner reset's to 100% if you open/close the door... but the machine corrects itself soon to 0%.
        On the other hand the machine works until the bottle is real empty.
        This workaround is good to bridge a few 100 prints if the customer has no new toner.
        • Tiagocang
          • Feb 2022
          • 62
          have fun.
          Thanks for the answer do you know how to put
          the 8 series the screen to display # of days remaining, or % left.
          • emujo2
            • Mar 2017
            • 1579
            Sorry, the days/% is only available for the I series (unless it's a firmware update), but there is a selection from 0 to 25 you can change to display when the warning is seen. Go into service mode and look at system 2/unit change settings. you will have to play with the settings as the manual does not indicate what value the range is for, E
            • tsbservice
              Field tech
              • 8075
              • FuserNoob
                Service Mgr, CISSP
                • Jul 2022
                • 162
                Thanks for the info,
                will this also reset the 'gas gauge' Toner Level display on the home screen? These things seem to be notoriously incorrect.
                • konicatoshiba
                  • Jan 2023
                  • 33
                  Best regards
                  code 34
