c220 print quality issues
  • lobopt
    • Feb 2023
    • 4
    Hi,
    Sometimes, when i print several pages they start looking like the attached file. Sometimes it doesn't. If i print one by one the quality is ok. Any thoughts?
  • tsbservice
    Field tech
    • 7979
    Re: c220 print quality issues
    Does it peel off the page when you rub paper with your finger?
    • tech51
      • 846
      Either your fuser is bust, or your not matching the paper weight on the machine (thick 1 etc) to your paper stock.
      • lobopt
        • Feb 2023
        • 4
        It peels off a little and i can feel the ink.
        The paper is usually 70 or 75.
        • tsbservice
          Field tech
          • 7979
          Then it must be something in between bad fuser, developer or toner.
          • davidmtupper
            • Jul 2021
            • 326
            Most likely a fuser as others have stated, but this machine is over 3 years past end of life. It might be time to consider letting it go in favor of something newer.
