bizhub C250i print scanned document
  • jwai
    • May 2018
    • 508
    Hello,
    I have 2 units C250i have same issue.
    Copy, print, scan are OK, if customer scanned a document to PC and printed it, the words have foggy edge. I cleaned scanner section ( lens, mirrors, platen glass, CCD ), check scan setting ( 300dpi, auto color, PDF, exposure and background removal default ).
    I observed this scanned image on PC, nothing problem. I tried to scan to USB stick and print, same result.
    Any idea about this case? Thank you.
  • Gift
    • Mar 2011
    • 2459
    Re: bizhub C250i print scanned document
    Sample looks fine to me except that the second page shows a little more compression artefacts around the letters,
    just zoom in a lot and you'll see it (if no, adjust brighntess/contast of your monitor)
    If the gradation setting is too dark these kind of artefacts may show up emphasised on the prints, too.
    My tips:
    - Delete the stabilizer/gradation data and run a new gradation
    - check the scan settings, use at least 300dpi and avoid compact PDF if prefer quality over filesize
    - check the drivers
    - use adobe reader for printing PDF
    - print in B&W mode
