FS534 FS537 FS539 SD
  • rrrohan
    • Sep 2011
    • 1977
    Got a FS539SD with really jammed up SD
    Are the FS534SD the same? SD511. The PWB is same part number so assuming I can recover a SD from the FS534 and install it in the FS539?
  • ronny2502
    • Mar 2020
    • 79
    Re: FS534 FS537 FS539 SD
    Hello,
    should work. Same part number for 527/534/536/539.
    Ro
    • rrrohan
      • Sep 2011
      • 1977
      i just looked the 539 SD has 2 wires that go from the board but the SD511 has 3 so I gave up.
      Its folding knife was in wrong position and was dug into the folding rollers so i reposition that but still giving C1196 errors.
      Im not sure if it had timing as gears on back didnt appear to have any marks on gears only the front gears had timing arrows
