C6500 Poor Image Quality and a million other issues.
  • HORSE
    • Mar 2008
    • 185
    #16
    Originally posted by bdobler
    hermann,
    Horse,
    What is "Try Drum Pec. > Recall Standard Data". Sorry for my blatant ignorance.
    Recall Standard Data is the very last option in the Drum Peculiarity Adjustment it
    Laughing......
    • HORSE
      • Mar 2008
      • 185
      #17
      hermann,
      Horse,
      Laughing......
      • bdobler
        #18
        Just wanted to check back here and give you and update. Things are looking better. My techs looked her over with all of your suggestions and made sure the 'bad' parts were updated. I found a thread at printplanet (C6500 w/ Fiery IC-303 - Screening Choices - PrintPlanet.com) that suggested using the Type 2 instead of 1 for the Line screens. Settings can be found
        Utility -> Machine Admin Setting -> System Setting -> Expert Adjust -> Quality Adjust -> Custom screen -> set DOT2 pattern to type 2.
        I have a top level analyst coming from KM first week of May so I will be back then to update this thread.
        Thanks once again for your help.
        • jma676
          Expert Tech
          • Mar 2009
          • 323
          #19
          Compare
          Ok Sendme the Ps Test Sample, I want copare with mi C6500 Because i keep This machine Running for 80k & 100 per month, and I Don`t have Problem with the image Quality.
          Ok Sensor Gamma to be Change.
