DF 633 Jam
  • pinspin
    • Oct 2011
    • 156
    [Jamming] DF 633 Jam
    Hello , friends . May be anyone else had a similar problem - DF 633 makes random jams 6602 . I replaced Feed Roller Assy and Clutch A161M20202 , but it did not help . I would be grateful for any advice .
  • pinspin
    • Oct 2011
    • 156
    Re: DF 633 Jam
    Bizhub C287i
    • allan
      RTFM!!
      • 5462
      Re: DF 633 Jam
      The pins that the DF cover latches onto could be bent up slightly due to it being ripped open. See if its bent and correct that if that is the case.
      Whatever
      • tsbservice
        Field tech
        • 8064
        Re: DF 633 Jam
        Is that happen after last page is being fed? Any strange noise at this moment?
        If yes your paper present sensor is dirty. Easy to solve
        • pinspin
          • Oct 2011
          • 156
          Re: DF 633 Jam
          no , its first sheets take up problem , but thanks for the reply
