C6500 calibration ?
  • totoro
    • 568
    C6500 calibration ?
    Hi All,
    I have a machine, 1 of 2 that I'm having problems with colors matching what is scanned. I have a 200k PM kit on order and will change all the parts, but I have been hearing conflicting things from different techs about which adjs to do and in what order to perform them. Can anyone tell me which adjs to do and in what order? TIA
    Totoro
  • pacman
    I can turn a screw...
    • 318
    For some reason, I thought the c6500 pro was self calibrating.
    • Si@danwood
      • Mar 2008
      • 154
      image qaulity adjustment
      The 6500/5500 is not self calibrating.The most accurate way of Calibrating the engine is with a Es-1000 spectrometer(For Fiery)or densitometer if using the Creo controller,Assuming all necessary drum perculiarty adlustments have been carried out 1st(See attached PDF)...Si
      • buster68
        • Nov 2008
        • 181
        The C6500 service manual has a list of adjustments and what order to perform them. The list is in Section 9, pages 232 & 233.
        • totoro
          • 568
          Thanx everyone.
          Totoro
          • mecanico
            Adjustments after maintenance
            Originally posted by totoro
            Hi All,
            Check This.
            • totoro
              • 568
              Well, I did all the calibration adjustments and they all completed, but the copies are still off. I have ordered an IP board and a ccd cable. Can anyone think of anything else? TIA
              Totoro
              • random
                So let me get this right you have two c6500 one that the scans print correctly and one that does not?
                Do you mean scan to the rip and print from the rip? Or do you mean photocopying?
                If it is the latter then I have had this problem with the ribbon cable from the CCD not connected properly at the board end (not ccd end) Just re-seat it and problem gone.
                • totoro
                  • 568
                  I mean copying off the glass. I have tried reseating the ccd ribbon cable with no change. It almost looks as if the machine is using processed black instead of true black. I only have 2 of these machines in my rural territory and the second one has no off street business so I am not that experienced with them. Is there a way to set it to use true black when copying off the glass?
                  Totoro
                  • HORSE
                    • Mar 2008
                    • 185
                    You can calibrate the scanner....!!!
                    Also check setting different type of original.... Photo, Map, Colour printed Original etc etc.
                    Laughing......
