758 958 transfer belt causing void dots
  • allan
    RTFM!!
    • 5449
    Hi guys.
    Was hopping that one of you know what inside the 758 958 transfer belt is causing the void dots. Approaching and passing the yield the solid prints starts getting void dot to the point where it needs to be changed. The belt surface still looks real good due to it having the cleaning brushes. I suspect it to be the sponge transfer roller for the primary transfer.
    Anyone had luck fixing this issue?
    Whatever
  • tsbservice
    Field tech
    • 7712
    Re: 758 958 transfer belt causing void dots
    @allan, I will play with Primary transfer adj. and 2nd transfer adj. to find if correction helps.
    • allan
      RTFM!!
      • 5449
      It just make it a little less worst adjusting the values. All the machines start with it near or after yield. Wondering if there will be replacement rollers for it.
      Whatever
      • tsbservice
        Field tech
        • 7712
        Sponge transfer rollers we use little soap and water to clean them on smaller MFPs/printers, I know some guys here even use car polish on them after cleaning, maybe worth a try.
        • Acadien
          • Nov 2009
          • 17
          Originally posted by allan
          Hi guys.
          Had same issue on different model, an i am pretty sure it is cause by the rollers inside the transfer belt. i replaced the transfer belt unit
