Please set Toner replenish unit message
  • Momiowilove
    • Sep 2019
    • 63
    [Misc] Please set Toner replenish unit message
    Good day engineers
    I have this Konica Minolta bizhub press C 8000. This machine is before working after the other technician handle it
    Before the problem is c2202 I already replaced the magenta developer developing unit and magenta drum.after I replaced this parts c2202 occurs and I check the I/o in state confirmation I locate the problem in the developing motor. After I replaced this motor and do the same procedure on the I/o state confirmation. The message has appeared on the screen PLEASE SET TONER REPLENISH UNIT. I already check all the sensor and the connection in printer controller board. And it gives me the same problem. Can you please help me to this problem Thank you in advance
