Konica Minolta C1100 - Please set replenish toner unit correctly
  • MR01
    • May 2022
    • 4
    Hello friends,
    Thank you
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: Konica Minolta C1100 - Please set replenish toner unit correctly
    Originally posted by MR01
    Hello friends,
    I have a problem with one Konica Minolta C1100: it appears “Please Set Replenish Toner Unit Correctly” but don’t have idea what to do. Please can someone help me?
    Thank you
    Check the screws that hold the toner replenish unit securely in place. Maybe they are loose or missing. If that's not the issue then maybe the switch is bad. Probably the screws though.
    • romario
      • Jun 2020
      • 192
      Hello friends,
      Thank you
      the hopper unit screw is loose or the switch is damaged, most likely the screw is loose and will not screw
      thanks
