Replenish toner message Bizhub C754e
  • escalante
    • Sep 2018
    • 115
    Good morning. I have the following message to replace toner. I already changed two toner bottles, please clean the black color toner tank and again replace another toner bottle. In this last toner change, I worked for two days and the message to replace toner appeared again. Please any suggestion is welcome.
    Enviado desde mi Infinix X693 mediante Tapatalk
  • splblazer91
    • Jul 2014
    • 204
    Re: Replenish toner message Bizhub C754e
    Make sure the pins that the toner bottle pushes against arent bent. Next Step would be Toner Sub Hopper.
    • tulintron
      • Jul 2014
      • 668
      Are you using original bottles? They should start toner life through the chip. If the answer is yes, the problem may be with the PRCB. The signal does not reach the chip and the information remains in the PRCB.
      evaluation needed
      • adfgdf
        • Jan 2022
        • 12
        Go to Service mode > State Confirmation > Level History 1 and check the TCR-K , it should be around 6.50% , if it is too low (under 5%) the tonner hopper might have a problem, perhaps its broken, something came off or you got clogged toner inside or something might be blocking the path of the toner going into the developing unit.
        Good luck!
        • blazebusiness
          SanDiegoCopierRepair.com
          • 1257
          Good luck!
          Agree, most likely due to a clog, or issue with the sub hopper.
