B4020i
  • gpais70
    • Apr 2018
    • 15
    B4020i
  • Max
    • Oct 2011
    • 561
    Re: B4020i
    What message do you get when you press Detail? Possibly drum/Belt over life. If it is, there is an override for it in the service menu.
    • tsbservice
      Field tech
      • 8030
      Re: B4020i
      Check toner/drum/fuser for mechanical binding. If anything is OK you may need new main board.
      • gpais70
        • Apr 2018
        • 15
        Re: B4020i
          • 14876
          Re: B4020i
          That looks suspiciously like a Brother display. Have you checked any Brother forums?
          • tsbservice
            Field tech
            • 8030
            Re: B4020i
            Because it's Brother rebadge.
            • JasonSBE
              • Apr 2014
              • 187
              Re: B4020i
              Service manual didn't give much information. I noticed the date and time are reset, did you set the date and time when you installed it? Could be a sign of issues with the MFP board. Here's a link I found from Brother regarding the message, hope it helps.
              "Print Unable 0B"
