bizhub 3510
  • bizhub1
    • Sep 2008
    • 230
    bizhub 3510
    I have a 3510 that will not lift the #1 tray and reads out of paper?
  • Luther
    • May 2006
    • 682
    Did you check for paper behind the draw?
    • bizhub1
      • Sep 2008
      • 230
      Yes, I had the cassette out and tried to get it to raise by tripping the sensors, nothing, thinking its a motor issue or board
      • mo0651
        • 1054
        When you check the input checks, is the cassette showing as set? Check the actuators on the tray. When you push the tray in it is supposed to hit the present sensor. Some of these have been damaged.
        • tech51
          • 846
          Check the limt sensor that is actuated by the feed tyre raising. I had one fail and got the symptoms you describe. To explain, it shows out of paper because the paper detect actuater is not actuated by the cassette, at the same time the failed sensor is telling the machine that the cassette tray is fully up. Therefore the tray does not rise. Hope this helps
