error message C-OF36
  • slvrcrk
    • Jul 2025
    I have a Minolta 2002 copier w/ printer. I got this message today and cannot find it in the manual. Help please!
  • ZeusGT
    • 271
    If I'm not mistaken ( I know, fixthecopier... he he) the error code that you have is the HDD code.. don't quote me exactly on that code, BUT.. you can find out what it is by going into the Tech Rep Mode and clicking the counter button, then click the trouble button and then you should be able to scroll till you see the code and it will give you a very BRIEF description of what it is.
    That's how I usualy find out what the codes stand for... hope this helps..
    CompTia A+ Certified
    CompTia Net+ Certified
    CompTia Server+ Certified
    CompTia Project+ Certified
    OP Scanshare Certified
    • B0265
      • Jan 2007
      • 718
      C0F36: Abnormally low toner density detected Black ATDC Sensor
      • slvrcrk
        C-Of36 error
        I just put in a new black Cartridge, It doesn't change anything. Whats next?
        Thanks for the help
        • Blenk
          • Mar 2009
          • 23
          it may be that the toner level is very low in the black unit, was the toner cart you took out completely out of toner before you put the new one in? to get it running you could try adding a little toner manually, you can view the toner ATDC levels in the level history in tech rep mode, it will probably be under 3% now, get it above that slightly and the code should go away then when you are able to run copys it may start adding and get back to the correct level of about 7%. when/if it gets to the 7% your image should be ok unless the black unit has had it run an image stabalize and grad adjust from the tech rep mode.
          good luck
