BH206 SMB send to server 2016 fail
  • Sing
    • Nov 2023
    • 8
    BH206 SMB send to Windows 7, Windows 10, Windows 11 works fine. But fail to send to server 2016.
    With the same setting on BH423, it works fine to send to server 2016 SMB.
    Can some one suggest what to fine tune on server 2016 to accept BH206 SMB traffic ?
    At the moment I am using FTP to server 2016.
  • CP-1015
    • Nov 2020
    • 325
    Re: BH206 SMB send to server 2016 fail
    It seems you send with SMB1 Protocol.
    Open PowerShell Ise as administrator and copy this lines in it:
    $Pro = Get-WindowsFeature FS-SMB1
    If ($Pro.InstallState -eq 'Available') {Enable-WindowsOptionalFeature -online -FeatureName SMB1Protocol}
    $1 = Get-SMBServerConfiguration | Select-Object -ExpandProperty EnableSMB1Protocol
    If (!$1) {Set-SmbServerConfiguration -EnableSMB1Protocol $true -Force}
    Then perform Enter. Maybe restart is necessary.
    • CP-1015
      • Nov 2020
      • 325
      I see, I'm wrong. SMB1 is on. Then test if SMB2 is enabled:
      $2 = Get-SMBServerConfiguration | Select-Object -ExpandProperty EnableSMB2Protocol
      If (!$2) {Set-SmbServerConfiguration -EnableSMB1Protocol $true -Force}
      • CP-1015
        • Nov 2020
        • 325
        What error code?
        • Sing
          • Nov 2023
          • 8
          Thanks for reply.
          [Caution Communication Error SMB Server]
          No changes after aply PowerShell command, Now I can only scan image to server 2016 throught FTP service.
          While as BH423 has no problem on SMB to server 2016.
          Happy week ends..
          • Sing
            • Nov 2023
            • 8
            This2.gifThanks Ronny, SMB for client, FTP for server, ans USB for Pen drive.
            Right ?
