Problem with konica minolta c224e it restarts continuously
  • enricocopyline
    • Jun 2018
    • 121
    I have a problem with a Konica Minolta C 224e it restarts continuously without giving error codes if I disconnect the hard disk it works but changing the hard disk gives the same problem.
    I also tried changing the RAM but it didn't solve the problem.
    what could be the problem? the nvram?
    can I solve it with a reset?
    thanks for the replies
  • ronny2502
    • Mar 2020
    • 78
    Re: Problem with konica minolta c224e it restarts continuously
    Hello,
    I think you should replace
    A5C1H02D15 - SSDB
    Good luck
    Ro
    • tsbservice
      Field tech
      • 7980
      Originally posted by ronny2502
      Hello,
      A5C1H02D15 - SSDB
      [ATTACH=CONFIG]60594[/ATTACH]
      Good luck
      Ro
      Yes, that's the culprit. Don't forget to update the firmware after installing new board.
      • Copier repairman
        • Aug 2019
        • 86
        Originally posted by enricocopyline
        Konica Minolta C 224e에 문제가 있습니다. 하드 디스크를 분리하면 오류 코드 없이 계속 다시 시작되지만 작동하지만 하드 디스크를 변경하면 동일한 문제가 발생합니다.
        RAM도 바꿔보았지만 문제가 해결되지 않았습니다.
        무엇이 문제가 될까요? 엔브람?
        재설정으로 해결할 수 있나요?
        답변 감사드립니다
        HDD is defective.
        After replacing the HDD.
        Please format your HDD.
        • Asaadahmed003
          • Jun 2019
          • 24
          Replacing the SSD should do the trick for you, and update the firmware after replacing the ssd
