Bizhub: light lines, bars on low intensity Black prints. [see scans]
  • MonksServant
    • Nov 2023
    • 5
    I've solved the C,M problems from this thread: https://www.copytechnet.com/forums/k...see-scans.html
    by replacing the transfer belt.
    However, what I've found now are those lighter stripes that show up on Black toner prints. What you're seeing here is a 50% black color.
    With 100% color only the uppermost line is barely visible.
    I have two B drums for comparison and both drums show the same lines in the same places. So, I guess it won't be the drum.
  • tsbservice
    Field tech
    • 8028
    Re: Bizhub: light lines, bars on low intensity Black prints. [see scans]
    Did you clean the laser by wand? Sometimes it is even advisible to remove laser unit(PH unit by KM) from machine in order to clean it properly.
    • MonksServant
      • Nov 2023
      • 5
      Yupp. You got it right, sir. Thank you very much.
      What it was, was some very stubborn dirt that I had to clean several times (around 20x).
      Also, I've used a micro-fibre cloth wrapped around the wand and I'm seeing an immense progress.
      There is still one line so I might need to remove the laser unit, as you've proposed.
      Thanks again.
      All the best
