Problem with Ineo 3351
  • Sencho
    • Feb 2023
    • 21
    Hello everyone,
    I would like your advice.
    I have a problem with the Ineo 3351. Its main drive gear was replaced due to the C2155 problem.
    After the replacement I had a problem with a faded image. I replaced the Imagine units CMYK, ITB, transfer roller, PWB.
    The problem remained the same.
    All springs are neatly attached and in contact.
    Do you know what else could be?
    Attached you will find a picture of the printout
  • jotunn
    • 624
    Re: Problem with Ineo 3351
    High Voltage unit?
    Looks like missing high voltage on transfer roller.
    Try to stop print (open right door) when the sheet begins to enter the fusing unit, remove transfer belt from the machine and look if the image is properly formed on belt.
    You can use HVPS from previous gen. machine (C3350) - part number is different, but they are interchangable.
