Boot rom c308
  • Max
    • Oct 2011
    • 557
    Boot rom c308
    Hi All. I am trying to reset a c308 using a tar file but it's not taking it. I seem to recall having to update boot rom for it last time. I can't for the life of me find it on Konica tech site. I don't suppose someone could share a copy.
    Many thanks and a happy new year.
  • tsbservice
    Field tech
    • 8016
    Re: Boot rom c308
    I used to be in same situation. On my donor machine it was boot rom 01 and I can't use reset tar. Searched and tried a handful firmware versions because of this fantom boot rom all to no avail. At the end swapped MFP boards and did firmware and so on and it worked. Go for it 😄
    • UKTeam
      • 24
      Re: Boot rom c308
      Its old....
      Boot program version G00-02 in the GG3-54 special release.
      A7PU0Y0-F000-GG3-54(00)
      Probably need to ask your rep for a copy...
      • Jumping Jack Flash
        • Jul 2009
        • 66
        Re: Boot rom c308
        Jesus, are you the service manager?
        Good luck in the New Year
        • Max
          • Oct 2011
          • 557
          Re: Boot rom c308
          Got to the bottom of it. Turns out there are two different tar files. (Who knew) the one I used only worked on 8 series (458 and above)and i series.
          • Roronoa Zoro
            • Nov 2024
            • 4
            Do you think you can send me the .tar for series 8?
