FM Audit
  • albemero
    • Apr 2019
    • 37
    FM Audit
    Hello everyone,
    we start this year to use FM Audit with Konica Minolta and Develop MFP too.
    For Develop MFP, TB - Drum und DV are shown, see image 2.
    For Konica is shown only toner, see Image 1.
    Anyone has a solution oder any ideas? ssw or something like that?
  • Saturn
    • Nov 2023
    • 171
    Re: FM Audit
    We are using FM Audit since 10 years. According to MHS, the display of consumables depends on the parameters provided by the Public and the Private MIB of the machine.
    At Ricoh we only see toners and waste toner containers, at Canon also drum units, fuser unit and the ADF maintenance kit.
    I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
    • tsbservice
      Field tech
      • 8001
      Re: FM Audit
      Originally posted by albemero
      Hello everyone,
      Thanks in advance for yours reply.[ATTACH=CONFIG]61287[/ATTACH][ATTACH=CONFIG]61288[/ATTACH]
      Set switch 230 to zero and voila
      • albemero
        • Apr 2019
        • 37
        Re: FM Audit
        I will test it. But I am Sure 227 is always 00 for Our Customer
        Gesendet von meinem SM-S901B mit Tapatalk
        • tsbservice
          Field tech
          • 8001
          Re: FM Audit
          This will show consumables in PSWC and machine panel.
          We almost always set them both zero.
