Macintosh Save in User Box C203
  • Wasfil
    • May 2008
    • 20
    Please.
    Spec : - Mac OS. 10.5
    - Driver C 203 V.5.0.1
    How to set about Print with Output Methode : Save in User Box, Secure print in Mac Os 10.5 ?
    Im did read and try from Manual book, but still can't. The problem is, menu User Box canot display so im canot input file name and user box number.
    give me advice
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    If you are not seeing all the options available to the printer it is usually because the printer driver is not being pulled from the proper location. go to the printers and choose the printer where it says driver choose other and navigate to the HDD, Library, printers, and so on, pick your driver from the last directory. Then make sure all your options are set including hard drive. You should now have your secure print or user box available.
    Good Luck
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • Wasfil
      • May 2008
      • 20
      Ok. Thanks,
      Im finished atrouble, i'm download and installed the new version of Driver (V.5.2.7). Thanks for all
